Problems with double extrusion
Hi everyone, I started using Prusaslicer recently (I always used Cura), in particular for double extrusion.
The problem arises when I process the files, I get a warning of an error that informs me about the presence of empty layers just where one of the objects starts (example z: 3.2).
I tried with different types of files (all for double extrusion) but I always get the same error, making it impossible to double-extrude.
How can I solve it?
RE: Problems with double extrusion
Can you save your print & settings off in a project (3MF) files, zip and upload it here? I'm having a hard time visualizing what you've described.
If it's a part floating in air, have you tried anchoring the part to the build surface (2nd button from bottom at left of PrusaSlicer screen)? Have you tried enabling support?
