Prints randomly force a filament change mid-print
captchemo
(@captchemo)
Recently my prints are randomly stopping and forcing a filament change.  It does it at random times, but usually early in the print.  Sometimes only once, sometimes multiple times.  Is there a filament or extrusion issue that would cause this, or is a software issue?  Anyone experiencing this problem?
Napsal : 21/11/2020 10:39 pm
RE: Prints randomly force a filament change mid-print
Posted by: @captchemo
Which printer and which slicer do you use? Filament changes normally only take place if they are triggered by the gcode file.
Napsal : 21/11/2020 11:49 pm
Keep looking and you will find a trend.  Nothing is random.  If it is random, look at your wiring.
Napsal : 21/11/2020 11:50 pm
Dodgy filament detection sensors also cause this issue.  If it detects no filament for a fraction of a second (problems with wiring, problems with switch etc) then it goes through the unload/load procedure.
I had it on my cr10s, the little microswitch it uses for runout detection stopped working reliably, I replaced it and no more problems.
Before I changed the extruder to a Bunny & Bear geared on on my Mk3 it also occasionally did it if the sensor wasn't cleaned out of filament dust.  Since the update that isnt a problem.
Napsal : 22/11/2020 12:18 am
@neophyl
I have two minis and each has an issue with the filament sensor.
Napsal : 22/11/2020 12:21 am
@cwbullet
On my Mini the original Prusa sensor didn't work either, that means the signal was inverted and wanted to print only without filament. For this reason I built my own construction and inverted the sensor signal. It's funny, because the sensor works with other people. But what the heck, mine works now and is even equipped with a control LED.
Napsal : 22/11/2020 12:40 am
@karl-herbert
Same issue here.
Napsal : 22/11/2020 12:59 am
Filament sensor. I've had this happen a few times. One way to check is to set filament sensor action in the settings menu to continue. If that ends the behavior you know where to look.
Here's the troubleshooting site:
https://help.prusa3d.com/en/article/ir-filament-sensor-troubleshooting-mk2-5s-mk3s_112226
Napsal : 22/11/2020 12:16 pm
@fuchsr
Yes, the Prusa Mini Sensor is also a hybrid version. It switches the contact through when filament is inserted but the firmware interprets this as not present. To check the switching process I installed a LED. I changed the Mini firmware to invert the signal. After the firmware change the Mini now detects existing or leaking filament correctly.
Anyway, it runs now.
Napsal : 22/11/2020 3:12 pm
MasterKoopa
(@masterkoopa)
I had random filament changes, no gcode related.
Happened when extruder motor get hot while in enclosure. Added a bit of cooling there and voila! No random changes anymore.
So filament sensor is fooled when in too hot condition. MK3S as printer.
Napsal : 10/04/2024 4:58 pm
1 lidem se líbí
Jake Freese
(@jake-freese)
Posted by: @masterkoopa
I'm going to have to check this tomorrow as like this evening it printed for an hour before the first forced filament chance then the intervals were getting shorter and shorter.  Heat makes sense.  I'll try running it with the door open, and check the extruder gear tension.
Napsal : 09/06/2024 2:30 am
Jake Freese
(@jake-freese)
I was able to reprint the part with the door open on the enclosure.  I did also back off the extruder tension to where the screw is 1 thread past the nut.  I also re enabled the filament sensor.
Napsal : 09/06/2024 11:17 pm
crystalcrest
(@crystalcrest)
I had "random" filament change triggers, and I traced the problem to a faulty gcode file.
My prints were working fine. Then I tried to change some (innocuous) print settings. In the process, I accidentally added one or more ticks to the vertical slider/ruler, and did not realize they mark filament changes at the marked heights. At each of those seemingly random layers, my printer would pause and ask for filament changes. My files which were printing smoothly without filament change were no longer printing without interruption.
To fix this, I had to click on the gear icon at the bottom of the vertical slider and choose "Set auto color changes." This will discard any markers for filament changes! So be careful if you indeed have filament change markers. If you do not have filament change markers or they have already been deleted, then choosing this option again will show a message "No color change event was added to the print." Regenerate the gcode, and you should be good to go.
Napsal : 27/05/2025 11:46 am
