Printing Test Square Grid - Make them print in sequence?
I have a test print file of a 5x5 grid of test squares for calibrating the z-offset:
When I slice it, I end up with what could essentially be described as a random order for printing the squares. I've attached a zipped version of the STL file I'm working with.
Is there some way I can get these squares to print in some kind of order? I don't care if it's left to right or front to back or all reversed. I'd just like to print them in some kind of order so it'll make comparisons and tracking which square was printed after which one a lot easier to track.
I don't know GCode at this point. I could find common lists of commands, but I think trying to go in and change coordinates in the GCode to do this would take me several tedious hours.
Publié : 30/08/2023 6:24 pm
