Printing marks problem - Ender 3 Max Neo
JohnMiller
(@johnmiller)
Hi, I don't know why it appears these marks in my prints. The first and second layer was perfect and the third one has the problem that you can see in the 2 photos.
It is curious that on the left side it is almost ok, and the marks appear on the right side.
General print settings Ender 3 Max Neo (I attach 3mf file):
  • 215º / 60º
  • PLA 0,24mm
Thank you in advance!!!!
Postato : 08/12/2023 4:18 pm
JohnMiller
(@johnmiller)
RE: Printing marks problem - Ender 3 Max Neo
I have find out the following weird things:
1) I'm printing with 0,24mm layers, first layer 0,20mm
2) I didn't see see Z position at first and second layer. But I see that layer 3 was 0,60 and the problems that you see appear at the 4th layer
3) When the 4th layer started I changed z-offset from -2.43 to -2.40 and now the 4th layer is printed correctly.
** When I slice the file 3mf (I attached it yesterday), the layers are 0,20, 0,44, 0,68, 0,92 ... Why the layers are 0,60 and 0,90?? **
Postato : 09/12/2023 12:25 pm
