Printing a stronger cylinder?
Summons
(@summons)
Hello,
I recently tried to print a 3 perimeter cylinder to shore up a vacuum cleaner part I managed to crack.  When I slid the tight fit part over the original part it failed at the point where the print started and stopped each layer - a line up the side of the part.
Is there a way to force the g-code to shift over 60 degrees on the cylinder as it begins each layer?
Spiral vase mode doesn't allow more than 1 perimeter Making the part very fragile...
Thanks in advance!
   E
Veröffentlicht : 23/04/2022 3:42 pm
RE: Printing a stronger cylinder?
Try Random seam.
Veröffentlicht : 23/04/2022 5:30 pm
Summons
(@summons)
Thank you - that solved it!
Not sure how I missed that in SETTINGS given I knew it was a 'seam' issue to ask the question!
Cheers,
   E
Veröffentlicht : 24/04/2022 1:17 pm
Cheers E,
we all miss things from time to time.
Veröffentlicht : 24/04/2022 8:14 pm
