Printer setting
YGiii
(@ygiii)
Printer setting
After configuration wizard, I still only have MK3 from the print setting list, but mine should have MK3 MMU2.
I took the model to printer and it said gcode sliced for a diferent printer type
Opublikowany : 28/02/2020 5:33 am
vintagepc
(@vintagepc)
RE: Printer setting
Make sure you select the correct *printer* first (bottom menu)
Opublikowany : 28/02/2020 3:04 pm
YGiii
(@ygiii)
RE: Printer setting
@vintagepc
Hi, no problem for the bottom setting. I am MK3S MMU2S.
The print setting quiet confused me. since it ends with MK3, am not sure if this is for my printer.
Opublikowany : 29/02/2020 6:00 am
