Printer profile for Monoprice Maker Select V2 3D printer
Richard
(@richard-13)
Has anyone created a PrusaSlicer printer profile for the Monoprice Maker Select V2 3D printer?
Or know, if there of an existing profile that is compatible with the Monoprice printer?  (I have printed couple items using the "Original Prusa i3 MK3S & MK3S+" profile and it seems to work.  But, the printable area is not quite the same as the Monoprice's.)
Best Answer by _KaszpiR_:
If that profile works for you then just enable expert mode, copy the profile and adjust the bed size in the new profile and save it?
Opublikowany : 12/12/2024 10:01 pm
_KaszpiR_
(@_kaszpir_)
RE: Printer profile for Monoprice Maker Select V2 3D printer
Opublikowany : 14/12/2024 7:48 am
Richard
(@richard-13)
Thank you.  I didn't occur to me that I could copy an existing profile.  Made things very simple. <G>
Opublikowany : 15/12/2024 12:37 am
outreachfirstclass
(@outreachfirstclass)
Since a USB connection won't work, you will typically need to print a Web Services Information Page from the HP Smart app or your printer's built-in menu in order to find a "Printer Code" or "Claim Code" for adding a sticker printer to your account. To access the printer's built-in website, locate its IP address, open it in a web browser, go to the Web Services menu, and then choose to print the information page. This printed page contains the code, usually located beneath the HP ePrint email address.
Opublikowany : 04/10/2025 5:46 am
