Print time estimate is bonkers
Pagina 1 / 2
mchahn
(@mchahn)
I have a sliced octopus (yum) that prusaslicer estimates a print time of 1 hr 54 mins.  Octoprint says 5 hrs 19 mins which is quite accurate.  I can't think of anything I could be doing wrong.  Has anyone else seen this problem?  I've enclosed my 3mf file.
Edit: Second try to add file.
Edit2: I cannot add the file.  I click the Choose File button, choose my file, and then when I save the post I don't see the file.  Is there something else I have to do after choosing the file?
Best Answer by mchahn:
My printer was set to a 35% feed rate with the M220 command.  I had set it slow when doing some tests.  After the tests I did an M502, which restores the hardwired settings from the marlin build.  Now I know that doesn't reset the feed rate (wtf?).  After setting the feed rate to 100% octoprint and prusaslicer agree within 18 seconds.  Apparently octoprint reads the feed rate before calculating print time.
The moral of the story is check printer settings when times don't match.  Maybe this will help some lurkers.  Sorry to waste everyone's time.
Postato : 10/10/2021 10:03 pm
MysDawg
(@mysdawg)
Slicer
What version of the slicer are you using?
Posted by: @mchahn
Postato : 10/10/2021 10:16 pm
sylviatrilling
(@sylviatrilling)
zip
You need to zip your 3mf file in order to attach it to a post.
Mk3S+,SL1S
Postato : 10/10/2021 10:22 pm
mchahn
(@mchahn)
added zip file
Thanks.  I'm not sure how I was supposed to know that 🙂   Zipped file is enclosed.
Postato : 10/10/2021 10:51 pm
mchahn
(@mchahn)
slicer version
My slicer version is 2.3.1 + win64.
Postato : 10/10/2021 10:54 pm
Swiss_Cheese
(@swiss_cheese)
@mchahn
My guess would be that Octoprint is slower then printing from an SD card, Ive printed similar products with derometer 60A using SD card and the estimation was within a couple of minutes.
BTW, way don't be a dick about posting photo's when people here help they are giving their time to help you, this is a community not the prusa business get off your ass and take some freakin pictures if it makes the people that are helping you feel better.
Regards
Swiss_Cheese
The Filament Whisperer
Postato : 11/10/2021 2:19 am
mchahn
(@mchahn)
sorry
Didn't mean to be a dick.   I am curious though what you mean by posting photos and to take some pictures.  Nobody said anything about pictures.
I don't believe octoprint would be 2.5 times slower.  The print is only 15 mm/sec and the gcode is the same either way.  I've done a zillion prints where prusaslicer and octoprint agreed on the time.  Something is wrong with this particular part.  Did you look at my 3mf?  Not saying you should, just asking politely.
Postato : 11/10/2021 4:18 am
Slicer & OctoPrint can use different methods of time estimation
Posted by: @mchahn
The PrusaSlicer estimates should be pretty close if you're using a Prusa printer. If you're using another printer, the machine limits do need to be set correctly to get good estimates. PrusaSlicer, depending on how you've configured it, will use a number of different methods of calculating print times, and some plugins will update print times during the print, so there's no reason they should match exactly.
Postato : 11/10/2021 5:06 am
mchahn
(@mchahn)
I will try to find the configuration that triggers the prusaslicer problem
I'm not printing this slice on a prusa.  This slice is for an old creality ender 3.  It doesn't have an sd card so I can't compare sd with octoprint.  But octoprint has nothing to do with this problem.  Octoprint is only slower when the printer eats the gcode faster than the raspberry pi can't send it.  At 15 mm/sec that's not going to happen.  I should not have mentioned octoprint in the original post.
Getting a good estimate is not the problem.  The problem is that prusaslicer is giving an absurd estimate.  Two hours versus five hours is not a difference that can be explained with printer settings.  And the print really does take five hours.
I also have the latest prusa printer and on previous slices the two printers have printed the (almost) same gcode with the same print time, within minutes.  The gcode determines the print time, not the printer.
As I said, I will try to find the configuration that triggers the prusaslicer problem (bug).  I posted here hoping someone else had seen the problem, or if anyone has any ideas what I could be doing wrong.
Postato : 11/10/2021 4:51 pm
geekandi
(@geekandi)
Utenti
Ender 3 V2 vs your set up
Ender 3 V2 on left, your settings on the right
Your 3MF file is printing in PLA though at these speeds and set up I gotta assume you're doing TPU.
Hope this helps you!
(ignore output filename format, I changed mine across the board for all my printers for better categorization)
Postato : 11/10/2021 6:03 pm
mchahn
(@mchahn)
ok, maybe I *am* a dick after all
Postato : 11/10/2021 6:10 pm
1 persone hanno apprezzato
geekandi
(@geekandi)
Utenti
Timewasting..
is what the internet is for, and pr0n.
Glad you figured it out - and that may have been on your display as well 🙂
Postato : 11/10/2021 6:15 pm
mchahn
(@mchahn)
My settings were wrong, but in the printer, not prusaslicer
Thanks, I will fix that.  Apparently though that mistake didn't affect anything.  See my answer above.
You're not the first!
Posted by: @mchahn
If you change those settings mid-print via the menu or knob, they are persistent until reset or a power cycle. I include gcode commands to reset M220 and M221 at the start of every print in my start gcode along with a few other settings. If you change those settings mid-print via the menu or knob, they are persistent until reset or a power cycle.
Postato : 12/10/2021 1:16 am
mchahn
(@mchahn)
RE: settings
Good plan.  I will do so also.
Edit: Although that will possibly make the octoprint time estimate wrong.
Postato : 12/10/2021 1:51 am
Guido666
(@guido666)
RE: Print time estimate is bonkers
Posted by: @bobstro
Posted by: @mchahn
@bobstro Is there a way to adjust Machine Limits (or other necessary print time calculation settings) for "G-Code Flavors" that disable the Machine Limits settings page?  My prints are consistently 25-35% off on time estimation.
Postato : 06/02/2023 5:20 pm
Change to marlin and set them to match your machine, change the drop down at the top of the limits to use for time estimate, then change to the flavour that doesnt use that tab.  Even though the tab is gone the settings are still 'there' and will be used for the time estimate.
Postato : 06/02/2023 9:01 pm
Guido666
(@guido666)
@Neophyl
Perfect, thank you, that's what I was wondering.
Questo post è stato modificato 3 years fa da Guido666
Postato : 06/02/2023 9:24 pm
Guido666
(@guido666)
Posted by: @neophyl
I just tried it, and PrusaSlicer does remember the Machine Limits settings after you switch the G-Code Flavor back (and the tab disappears), but it does not continue to use the Machine Limits to calculate print time unless a G-Code Flavor is selected that enables the Machine Limits tab.
I asked on the Discord channel, and Tojik (Prusa Mod) responded...
well it looks like you should be able to switch to RepRapFirmware and it being fine, it supports machine limits and so on. I've read something about a wipe tower complicating things (edited)
some sources:
https://forum.duet3d.com/topic/19389/prusa-slicer-2-3alpha2-adds-new-g-code-flavor-for-rrf
https://forum.duet3d.com/topic/5181/slic3r-prusa-g-code-flavor (M900 M907 and wipe tower stuff)
Postato : 06/02/2023 10:51 pm
I tried it with 2.5 and a flavour that didn’t have the tab and the slicing time estimate was same between marlin Legacy and the one I changed it to .  Think there was about a minutes difference.
Postato : 06/02/2023 11:03 pm
Pagina 1 / 2
