Print stops?
Derrick
(@derrick)
Print stops?
I just bought 2kits Mk3s, the build went wel also calibration etc is al good. Next I installed de Prusa slicer (Mac version). I was all pretty straight forward. Stared a print, the same on both printers. Started perfectly till about 80% was printed. Both printers gave a warning signal to remove the filament en then reload it. Then it printed the rest? I have been searching in Prusa Slicer if I had missed a setting that woud cause this. Can someone shed a thought on this. Would be much appreciated.
Postato : 09/10/2020 1:58 pm
Utenti
RE: Print stops?
Which item are you printing?  It makes me wonder is this is a 2 part print built into the GCode.
Postato : 09/10/2020 3:02 pm
Derrick
(@derrick)
RE: Print stops?
No its's a one piece. one color
Postato : 09/10/2020 3:05 pm
Utenti
RE: Print stops?
@dvgeest
You did not answer my first question.  What are you printing?
Postato : 09/10/2020 4:05 pm
Derrick
(@derrick)
RE: Print stops?
Sorry, a very simple bracket with support.
Postato : 09/10/2020 4:12 pm
RE: Print stops?
You could have accidentally added. Colour change command at the problem layer. If you save your project, zip it up and attach it we can look. If you didn’t save the project you could zip up and attach your g-code.
Postato : 09/10/2020 4:16 pm
Utenti
RE: Print stops?
@neophyl
That would help.
Postato : 09/10/2020 4:19 pm
Derrick
(@derrick)
RE: Print stops?
OK, I’ll make a new slice and look out for the color change, that sounds like wat has happend! Thankz
Postato : 09/10/2020 7:09 pm
RE: Print stops?
You might do a text search of the gcode file for M600.  If it is in there you probably clicked a box unintentionally.
Postato : 10/10/2020 1:10 am
