Print settings profiles gone?
kassi
(@kassi)
When I first started PrusaSlicer and played around with it after setting it up for my needs (printer, filament, etc.), I was able to select 0.30mm (DRAFT or STRUCTURAL, not sure) from the print profiles.
Now, still using Original MK4 Input Shaper 0.4mm nozzle, I can only select between 0.15 and 0.20mm. (standard profiles).
Where is 0.3mm gone? What makes this go away? I didn't delete anything for sure.
And how to get it back.
Napsal : 20/10/2023 5:22 pm
RE: Print settings profiles gone?
The 0.3 DRAFT setting is only available for the non-IS printer profile.
Napsal : 20/10/2023 8:24 pm
kassi
(@kassi)
Ok, thanks. Interesting because I had this at the beginning, but then after slicing several parts, it was gone.
I had the feeling it was gone after loading a gcode file into PrusaSlicer (instead of stl), but I can't approve this.
Napsal : 21/10/2023 1:04 pm
GeneMpls
(@genempls)
Why... why... why? I have spent many hours trying to get this info. I am old and now I am older. Gene
Napsal : 22/11/2023 5:38 pm
Dan Kidd
(@dan-kidd)
I had this exact issue - I had updated from prusaslicer 2.6 to 2.7.  Everything good, but after importing from a 3MF file - a lot of profiles went missing including the 0.3 profile.
If I go back to 2.6 i believe they are there.
uninstall and reinstall 2.7 and I can see now that 0.3 and other profiles come with MK4 without input shaping.  So if in configuration if you install both mk4 input shaping and mk4 without you will get all the profiles - But if you select 0.3mm then your printer will change to the MK4 without input shaping, I'm guessing incompatible or not developed?
Napsal : 08/01/2024 1:10 am
