Print parts of parts one after the other, not by layer
ygoe
 ygoe
(@ygoe)
Hello,
I know and use the option to print multiple parts one after the other in their entirety. But what about parts of parts? Look at the attached print. The PLA is probably not as dry as it could be anymore. So the strings reach between all the vertical parts.
If those 4 pillars would be printed one after the other, the stringing would be gone and the print would be faster because the print head wouldn't need to run from corner to corner but could finish its thing in one corner and then move to the next. Their distance looks sufficient for the print head to fit in.
Is this possible?
Veröffentlicht : 19/02/2026 8:12 pm
UjinDesign
(@ujindesign)
RE: Print parts of parts one after the other, not by layer
Posted by: @ygoe
Is this possible?
If you're up to editing g-code it's most certainly possible, since the pillars don't seem to be close enough to clash into the print head (maybe the pillar are high enough to clash into the x-axis rails though). But just because it's possible doesn't mean it's worthwhile time-wise though.
I don't think we'll see a solution to easily do this implemented in Prusa Slicer anytime soon. The scenario you're showing, i.e. multiple areas that benefit from being printed in sequence but still being far enough away from each other that the print head won't clash with them, is very niche. Again, it's possible to do this by editing g-code but I can only see that realistically being done on production-FFF where you're printing like 100+ of the same component where putting in the time to edit the g-code would be worth it.
Just my two cents!
Veröffentlicht : 19/02/2026 8:29 pm
Conrad
(@conrad-2)
IMO, it would be a great feature, but I think it would be tough programming challenge. Maybe (banish the thought) even requiring AI!
Veröffentlicht : 19/02/2026 9:02 pm
