Print freezes, prints fine when rotated
Macgyver
(@macgyver)
I decided to try using prusaslicer for a printer I built. I have been getting great results when they print, thought the reliability is hit or miss. I am using a duet 3 with a pi. I have several parts that would only print a portion of the skirt, and then the printer would stop. no errors or anything, it would just stop. I was actualy about to give up and then I decided to try and rotate the part 90 degrees and reslice and then part printed fine.
Also, the acceleration adjustment produces a M204 S where as reprap calls for M204 T. As such I am unsure if these settings are being applied. Though I do have significantly less ringing than I get with Simplify3d.
Respondido : 03/01/2021 5:11 am
mrstoned
(@mrstoned)
RE: Print freezes, prints fine when rotated
Check in slicer;
Printer Settings -> Firmware Flavor
It is visible under Expert mode.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Respondido : 03/01/2021 11:39 am
Macgyver
(@macgyver)
@mrstoned
I've got Reprapfirmware selected as I read it is intended more for the duet and the reprap/sprinter is more of a workaround for some marlin users.  Also I am using 2.3.0 RC2
Respondido : 04/01/2021 9:20 am
