Possible bug: travel lift not configurable
Hi, I have PrusaSlicer 2.7.4, and using Mk4 printer.
For a delicate print, I tried disabling "ramping lift" and setting travel lift to 1mm. But when I stepped thru the gcode, I didn't see any 1mm Z change.
So I exported two gcode files, one with ramping lift and one with normal lift set to 1mm.
The ONLY differences in the entire gcode file are the "generated date" and "; travel_ramping_lift = 1" changed to "; travel_ramping_lift = 0".
I expected to see a lot of other gcode changes as well.
Opublikowany : 03/06/2024 11:21 pm
