positioning object above spring steel sheet
Aryser
(@aryser)
Is there with Pruse slicer a way to positoning a object some distance above the spring steel sheet?
(my objets go always in touch with the spring steel sheet)
I want to bridge this distance with support.
With suport everywhere I hope for a nicer printed bottom surface, on objects with no flat surfaces.
Opublikowany : 06/05/2021 5:19 pm
RE: positioning object above spring steel sheet
Look up RAFTS.
As for using supports to create a nicer bottom surface? lol. The only place I have seen rafting help, is a triceratops skull example print. And the texture of the surface is perfect for an old skull - like sand paper. If that's what you are going for, rafts should work for you.
This post was modified 5 years temu by --
Opublikowany : 06/05/2021 7:07 pm
Aryser
(@aryser)
this ist the object!
https://www.prusaprinters.org/prints/66035-reuleaux-tetrahedron-with-constant-diameter
Opublikowany : 06/05/2021 7:48 pm
@tim-2
A raft created a less than desirable surface in my book.  It is often rather rough.
Opublikowany : 07/05/2021 2:40 am
@cwbullet
What the OP is asking for is exactly what a raft is for. And yes, the results from Prusa Slicer are not what many of us would consider 'acceptable' ... I called it sand paper rough ... but, it performs the requested function of supporting an object off the build plate within Slicer. I've heard Cura does better at rafting.
@aryser
Have you found the raft settings yet?
ps: you'll still need to enable supports.
This post was modified 5 years temu 3 times by --
Opublikowany : 07/05/2021 3:06 am
@tim-2
I am not sure I would call Cura acceptable either.  Maybe it is marginally better.
Opublikowany : 07/05/2021 3:10 am
Posted by: @cwbullet
[...] I am not sure I would call Cura acceptable either.  Maybe it is marginally better.
Supports are one of the few remaining areas where PrusaSlicer lags behind. IME:
  • Cura's tree supports are much nicer to work with than "platform" supports when doing irregular shapes like miniatures.
  • ideaMaker's platform-style supports are much cleaner when supporting large flat surfaces.
That said, it sounds like Team Prusa is working on supports soon, so I expect PrusaSlicer will move ahead in these areas in the not-too-distant future. I don't see anything about this particular print that would benefit hugely from using another slicer. I'd try rotating the tetrahedron 180 degrees to minimize the amount of support contact required:
I know Angus of the Maker's Muse YouTube channel prints a lot of these shapes. He's probably got some tips on printing for the cleanest result.
Opublikowany : 07/05/2021 5:30 am
@bobstro
I hope you are right.  I just tried idea maker and it is superior.  I will try Cura again.
Opublikowany : 07/05/2021 9:56 am
