Position correction of external perimeter of lower layer
[Risolto] Position correction of external perimeter of lower layer
Ray123
(@ray123)
Hi,There
The external perimeters of the lower (first and second) layers are drawn slightly inward of those of the higher(third and higher) layers .(when viewed in cross section, they taper toward the bed)
Is it possible to set all external perimeters to the same position (wall stands 90 degrees to bed)?
I'm trying to make a stencil for drawing letters on a cloth with water-based paint, so if the lower layers are tapered, it will bleed, which is a problem.(T_T)
Best Answer by KevinK:
I suspect that you are seeing elephant's foot compensation.  There is a setting for it in the print settings, advanced, toward the bottom of the page.  Setting it to 0 may fix this.
Postato : 02/07/2020 11:32 pm
KevinK
(@kevink)
RE: Position correction of external perimeter of lower layer
Postato : 03/07/2020 3:22 am
Ray123
(@ray123)
Hi,Kevin
As you told me, I set "elephant's foot compensation"to zero, the data changed clearly and the printed matter could be output sharply!
Thank you!
Postato : 03/07/2020 4:56 am
