Please allow cloud account storage of PrusaSlicer settings
Would you like to have your profiles and Slicer settings stored and manageable in your prusa account online? Poll is created on Mar 25, 2023
mgrobins
(@mgrobins-2)
I'd like to raise the feature request of having an option for cloud account storage of Prusaslicer Profiles so those of us who wish to can print and work from multiple devices.
Having gone through the process of calibrating and fine tuning it is also awful to have all of your hard work go up in smoke if something goes wrong  (Backups aside).
Cheers 🙂
Mgr Stock Prusa Mk3S+ using Octoprint in a passive enclosure.
Australia based, mostly printing eSun or Prusa filaments.
Respondido : 25/03/2023 10:46 pm
It's already possible, just sync the ~/.config/PrusaSlicer folder on each machine to one one the cloud.  If you're working within range it's better to symlink to a folder on a central server on your own network, or even to a usb drive plugged into your router.
Respondido : 26/03/2023 4:28 am
RE: Please allow cloud account storage of PrusaSlicer settings
That's what I do. I use symlinks to sync the config directory to a OneDrive folder. I've also used iCloud. And I'm sure Dropbox would work as well.
Having said that, I totally support the OP's suggestion. Makes a lot of sense to me to have a native sync solution rather than relying on an approach that requires a bit of advanced understanding of technology.
Respondido : 26/03/2023 3:48 pm
miremaker
(@miremaker)
Miembro
How does one do this? I have google drive. I've located the Prusa folder in my app data folder, but how can I sync this across machines?
Respondido : 06/09/2023 9:36 pm
I wouldn't trust anything to Google - they already know too much.
If you don't know how to setup sync then an simple symlink to a NAS on your local network is actually better if you're not going to work off site.
Respondido : 07/09/2023 3:21 am
Here's how I do it using OneDrive. Google Drive, Dropbox, local NAS, should work the same.
  • Go to Prusaslicer's Help menu and select Show Configuration Folder
  •  Go up one level and note the location/path name of the folder. It's usually /Users/username/Library/Application Support/PrusaSlicer (alphas and betas have different names). On Windows, it would look like C:/Users/username/AppData/Roaming/PrusaSlicer or similar.
  • Create a backup copy, just in case.
  • Copy the configuration folder to your network drive and delete the original. Note the new pathname, in my case /Users/username/OneDrive/3D Printing/Software/PrusaSlicer/PrusaSlicer
  • Open a terminal window.
  • Create a symlink on each computer on which you want to sync it:
ln -s /Users/username/OneDrive/3D Printing/Software/PrusaSlicer/PrusaSlicer /Users/username/Library/Application Support/PrusaSlicer
What all this does is create a "master copy" of the config folder on a network drive (OneDrive/Gooogle drive/Dropbox handle the syncing of that drive across machines in the background). The symlink creates a pointer to that folder in the location PrusaSlicer looks for the config folder.
Esta publicación ha sido modificada el hace 2 years 2 veces por
Respondido : 07/09/2023 9:19 am
klepp0906
(@klepp0906)
Miembro
IMO this is one of cura's big +1's
Very hopeful a native cloud/backup solution gets added.
Respondido : 14/09/2023 3:16 pm
tr1pp4
(@tr1pp4)
Miembro
It looks like Prusa is not a fan of this idea. They want us symlinking and copying forever
Respondido : 22/09/2025 10:13 pm
Mike B
(@mike-b-3)
I use a combination of Windows and MacOS and run PrusaSlicer on both.  Will the same config file work on both platforms?  I would expect it to, but you never know...
Prusa MK4 since Jan 2024, Printables: @MikeB_1505898
Respondido : 23/09/2025 3:05 am
