Persistent custom gcode
Hi! Is there a way to have a custom start gcode that survives updates and remains always the default one? Thanks
Posted : 17/10/2025 8:45 pm
RE: Persistent custom gcode
Yes. You just have to modify your printer profile with your changed start gcode, then save it as a copy with a custom name. Once you have done that you can then go to Printers>Dependencies and click the 'Detach from System Preset' button and then save it again.
At that point ANY changes wont be pushed to your new custom preset. As its detached. As you still have the default installed though you can periodically compare your custom to the default using the compare tool and IF you want any of the changes you can then manually push them across and save it.
Posted : 17/10/2025 9:10 pm
