Perimeter blobs in between external perimeters
I'm trying to slice an object with walls that intersect and the center area is exclusively a small blob of perimeter that I'd like to not print at all. Is there any way to filter out perimeters under a certain size? Some of these are larger than the size of the nozzle, but I'd like to skip them anyway to save a lot of time.
Opublikowany : 01/11/2024 5:59 pm
Tweak the wall thickness. Currently there is room for two extrusions and a tiny bit more that is too thin for an extrusion but where they intersect the volume is just enough to insert a blob.
Alternativly increase the external perimeter extrusion width - but this might have undesired side effects elsewhere on the print.
Opublikowany : 01/11/2024 7:37 pm
