Pausing or stop a print overnight or printing in two step or several step in prusa slicer.
Simbio3D
(@simbio3d)
Is it possible to have a feature on the Prusaslicer that can stop a print,  switch off the printer, and start again where it was left?
Or is there a tutorial step to organize the gcode to do that, I am quite a newbie but I do understand the is possible.
thank's for any hint
Postato : 27/03/2021 11:37 am
RE: Pausing or stop a print overnight or printing in two step or several step in prusa slicer.
there is an issue with turning the printers off.
the build plate is likely to cool,
and release the model...
if your filament sensor is working, you could cut the filament, wait for the sensor to report the issue and start beeping, then click the button to unload the filament and shut the beeper off, then leave the printer over night!
this will keep the heat bed heated but turn the extruder off...
alternatively you could use the LCD menu, to set the beeps to  off or another setting.
Postato : 27/03/2021 1:43 pm
Simbio3D
(@simbio3d)
@joantabb
Thank you
Postato : 27/03/2021 6:07 pm
