path planning feature - where is it in 2.2.0?
SleepingGiant
(@sleepinggiant)
Where is the better path planning feature enabled in PrusaSlicer 2.2.0?
Reading this blog post about PrusaSlicer 2.2.0 it says
Another change majority users will definitely welcome is better path planning – your prints will be faster thanks to optimized routines for path planning. Check out the screenshot below, it’s a pretty nice difference. And speaking of path planning, if you use the sequential print feature, you can now easily set the order in which the objects will be printed.
Publié : 11/04/2020 8:34 pm
TurboCooler
(@turbocooler)
RE: path planning feature - where is it in 2.2.0?
It built in, there is nothing for you to do.  After you slice click the "Travel" check box at the bottom.  This will show you the path your Prusa will follow.
Publié : 12/04/2020 12:47 am
SleepingGiant
(@sleepinggiant)
Thank you enzo-m,
I guess the travel paths I was seeing did not appear more logical at least on the couple of scenes I tested. Not a big deal. Good to know it's just "there".
"USB drive safe unmounting" works well for me.
Publié : 12/04/2020 9:48 pm
