Paint on Fuzz Question
john.f5
(@john-f5)
Hi all, in 2.9.2, how can I control the parameters for paint on fuzz.  The default appears to be thickness of 0.3, fuzz point distance of 0.8.
I like 0.1 and 0.1 for one project.  How do I do that with paint on fuzz?
Thanks!
John
Postato : 22/04/2025 9:40 pm
Sembazuru
(@sembazuru)
RE: Paint on Fuzz Question
I've found how you can change the fuzz parameters. You need to add the fuzz parameters to the object or a modifier on the object. Here is a demonstration with pictures (click on the picture thumbnails to see the full image).
I'm using the low-poly bunny from the PrusaSlicer gallery. I've painted fuzz as a sweater:
In the model tree on the right of PrusaSlicer, right click on the editing icon for the object:
Select add settings/fuzzy skin:
Select the two parameter settings and click OK:
Here the parameters are available to change with the values from the current print settings:
And this is what the sliced bunny looks like:
Now I change the values for the settings to your suggested 0.1 & 0.1:
And this is the slice with the new values:
Now we can be clever and selectively apply the finer fuzzy skin parameters only to an area on the object with mesh modifiers. I chose to use text (but any modifier shape can be used). I then apply the finer fuzzy skin parameters to only the text. The object tree will look like this:
And the sliced bunny looks like this:
Yes, it is subtle using text (I used a Black font variant here), but imagine branding something with your SVG logo in different fuzzy skin densities.
If you want to play with these settings or take apart exactly how I did this, here is the 3mf of the final bunny: FuzzyBunnyTesting
See my (limited) designs on:
Postato : 23/04/2025 3:49 pm
