Override PrusaSlicer Layer Height and Extrusion Width Limits and Ratio checks
bholness
(@bholness)
Hello,
I'm doing some experimental work using my MK3S as the motion system for extruding a liquid resin into a gel support bath. In my work I've discovered that the geometry of a single extrusion of this material is different to how 3D printed extrusions are normally modelled. My material has a typical ratio of extrusion width/layer height of ~0.67 which is opposite to how we normally model 3d printer extrusions where the width is larger than the height.
I know this will limit the geometries I can produce but I am wondering if it possible to override the safety/print quality checks in PrusaSlicer in order to allow me to model a more representative extrusion geometry for this application? I will also keep in mind to maintain reasonable modelled volumetric flow rates to avoid stressing the extruder stepper driver.
Thanks,
Ben.
Best Answer by Neophyl:
You need to post over on the Prusa slicer GitHub for this sort of thing, you will probably get much more help there. This is a user to user forum and while there are guys here who can compile the firmware the devs ‘live’ over there.
https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
Opublikowany : 27/07/2021 4:33 pm
Opublikowany : 27/07/2021 4:41 pm
bholness
(@bholness)
Thanks for the clarification and advice. I will post to the GitHub.
Opublikowany : 27/07/2021 6:01 pm
