Output Filename format when using a Project File
Webdad
(@webdad)
I'm a refugee from S3D where I used Factory Files to basically establish a locked in gold standard for my print job profiles.  Regardless of how individual pieces of a profile were changed in the S3D environment overall, reloading the original factory file always brought me back to a known state.
It seems like the Project file concept is a close match, but I'm struggling with trying to work out the placeholders for the Output Filename format.
My workflow is to load the project file (CR10sPRO-Standard.3mf) and then load up the bed with a print model (TanksMachines-v3.stl).
My output filename format uses [input_filename_base] in the filename, but the resulting output is: CR10sPRO-Standard as opposed to TanksMachines-v3
I've looked for the placeholder list, but can't find one that even includes input_filename_base.
Realize that a print may have multiple models, but I think S3D just pulls the first or last one in the list to propose a filename.
I'd prefer not to have to save every job as a 3mf with a new name before exporting the gcode.
Any other options to get this to work in this manner?
Thanks!
Publié : 22/12/2021 6:49 pm
micha
(@micha)
RE: Output Filename format when using a Project File
I suppose you're looking for https://help.prusa3d.com/en/article/list-of-placeholders_205643
That's about everything I found, but it covered all my wishes regarding filenames.
Mike
Publié : 22/12/2021 7:16 pm
Webdad
(@webdad)
Thanks, I found that as well, but it is missing [input_filename], [input_filename_base], to name a few.
Regardless, I've been continuing to play around with this and not sure what I was doing previously, but now it appears that [input_filename] is honoring the loaded models as opposed to the .3mf project filename.  I'll continue to futz around with it.  I wonder if the original behavior was due to my project file originally having a model loaded?
Not sure, but for now, looks like it was a problem between the chair and the keyboard.
Thanks.
Publié : 22/12/2021 7:26 pm
micha
(@micha)
You're right, and researching for information reveals many dead ends.
There is some information in the Wiki ( https://github.com/prusa3d/PrusaSlicer/wiki/List-of-all-placeholders-taken-from-the-code)
which didn't shed much light on my (non-programmer) questions. But at least it includes input_filename_base. 😆
When trying to find out about the macro language itself, you're taken back to the previous list.
Publié : 22/12/2021 7:57 pm
