Output file name - (print_time) in hours and minutes instead of days hours minutes.
vahid
(@vahid)
Is it possible to configure the output file name to have in hours and minutes
e.g 44h 51m instead of 2d 20h 51m
formula for it would be something like this ?>>>     {int(print_time/3600)}h_{int(print_time%3600/60)}m
Thanks
Postato : 10/12/2025 5:35 am
Sembazuru
(@sembazuru)
Possibly not. The {print_time} placeholder returns a string that in your example would be "2d20h51m" and I don't see any string manipulation functions in the macros help page. Although, I do see that regular expressions are supported. Maybe using regexp you can extract the values for days, hours, and minutes, add days*24 to the minutes. I barely know what I'm doing with regexp to formulate any experiments and the examples I see in the provided profiles are very basic.
Questo post è stato modificato 5 months fa da Sembazuru
See my (limited) designs on:
Postato : 10/12/2025 5:37 pm
vahid
(@vahid)
RE: Output file name - (print_time) in hours and minutes instead of days hours minutes.
ok, is there a way to also assign the same format to the project file name (not the g-code file)
Postato : 11/12/2025 1:55 am
Sembazuru
(@sembazuru)
I've only ever controlled the project file name with "Save-As" which as far as I know doesn't use PrusaSlicer placeholders being an OS GUI widget thingy.
Postato : 11/12/2025 6:15 pm
ssmith
(@ssmith)
Print settings, expert mode, output options, output filename format is where it is set.The placeholders break out day and hours, but I don't know if you can do math with them.
Postato : 11/12/2025 6:32 pm
