[Résolu] organic Support structures
juerg
(@juerg)
Membre
Having printed parts with organic Support I wonder whether I could print the Support separatedly. They Look sometimes amaizingly but usually break When removing the part
Publié : 17/09/2023 3:50 pm
RE: organic Support structures
Supports usually are defined with a thinner extrusion width when compared to the part. This means it uses less material and makes the, easier to remove. If you wanted to keep the supports you could define the support extrusion width to be thicker which would make them stronger.  You can also change the settings so they are double walled for more of the height/diameter.
Publié : 17/09/2023 6:24 pm
