Organic Paint On Supports Randomly Cease Working
T_om
 T_om
(@t_om)
Paint on organic supports worked in one of the 3mf files enclosed, yet would not in the other.  Making me crazy because the "Support" tab in both 3mf files were set exactly the same in the one that failed.
In the W1R 3mf file, notice the 4 paint on dots on the side of the wing are not being recognized, although the flat areas are.  In the other 3mf file, the dots work.
Any suggestions would really be appreciated.
Tom
EDIT: Will only allow one 3mf file I guess, will post again with the one that worked.
Postato : 21/08/2023 5:15 pm
RE: Organic Paint On Supports Randomly Cease Working
Normally (as in before the forum update) you have to zip files that you want to to attach.  None of your files are attached so it looks like even after the update that is still a factor.  Or it might be that like so much of the forum since the update attaching isnt working at the moment.
Postato : 21/08/2023 5:44 pm
T_om
 T_om
(@t_om)
I'll zip them both and try again.
Tom
Postato : 21/08/2023 6:08 pm
