Order of color on a multicolour print with sequential objects
multivir
(@multivir)
Miembro
I want to print multiple instances of the same object. The object has a thin logo (single lines) in a different color than the rest of the print.
The logo is only on the first layer. So in order to get a clean print, I need the logo first, then the rest of the material. That works fine on MMU3 prints when I do single objects or a lot of objects at once.
Since the object is somewhat delicate to print and I have some failures, I wanted to change to sequential printing. That way, if something goes wrong, I don't loose a whole build plate of material, but just a single print. Since I have some support material, I don't need a wipe tower.
However, for some reason I don't understand yet, I was not able to get PrusaSlicer to do the logo first - no matter where the logo is in the order of objects within the 3MF file / order in the slicer - nor does the order of the filaments in the MMU have an effect.
It is just not possible to do that in PrusaSlicer or did I miss something?
Thanks!
Respondido : 25/12/2024 11:36 pm
