option for brim offset
can we get an option for a brim offset like when using a skirt?
quite often the brim is very difficult to remove and a very slight offset (half nozzle diameter) would help greatly
Opublikowany : 22/10/2019 3:21 am
RE: option for brim offset
Isn't the idea for a brim that is should be attached well enough it holds an unstable part down? Making the brim semi-attached seems to circumvent the reason it is needed.
Opublikowany : 22/10/2019 8:26 am
I found a 0.15mm gap was ideal when I used Simplify 3D. Held the part down securely, yet just enough gap to provide a perforated edge effect that peels off easily.
Opublikowany : 22/10/2019 8:52 am
Topic starter
answered:
@bobstro
This had been my experience manipulating the skirt settings in prusa slicer to act as a brim, but this only works when printing a single model on the build plate. Having a brim offset solves this
Opublikowany : 22/10/2019 9:09 am
