open 3mf via command line (slic3r API)
I do have issues to open 3mf files via slic3r API in prusaslicer 2.5. The behavior for 3mf import is pretty strange. By default he is NOT handling a 3mf with multiple bodies like a "multi body" print. Instead he is pulling all single bodies to the build plate and messing everything up.
The GUI is asking how to handle the 3mf bodies (if they should be grouped and kept in position, or if they are distributed as single bodies)
Is there a workaround for this? For my understanding the default action for a 3mf file with multiple bodies should be "keep all single bodies in its position as it is one file".
Help and tips regarding API workarounds are appreciated.
Regards, Andy
Opublikowany : 11/12/2022 12:57 pm
