"only g-code for fdm printer can be uploaded"
Bas
 Bas
(@bas-2)
I have a Prusa MK3S with an attached Raspberry Pi Zero 2 W running PrusaLink. In Prusaslicer, I can slice a model but when I click the Send to Printer button, PrusaSlicer fives this error:
HTTP 415: Unsupported Media Type
Only G-Code for FDM printer can be uploaded.
I'm using the Original Prusa i3 MK3S & MK3S+ preset, so it's a mystery to me why it thinks it's not GCode for an FDM printer. In fact, if I export the Gcode to a file, upload it in the PrusaLink browser page, it uploads and prints just fine.
I've attached the offending gcode but it happens with every model I try to slice and print. I'm using PrusaSlicer 2.9.4 on Ubuntu. Here's the PrusaLink version info:
API 2.0.0
Firmware 3.14.1-8237
Server 0.8.1
SDK 0.8.1
Frontend 3.12.0
Any idea what could be happening?
Publié : 05/06/2026 11:07 am
_KaszpiR_
(@_kaszpir_)
RE: "only g-code for fdm printer can be uploaded"
Check if you accidentally have binary code enabled ( should be not), or tey much shorter file name.
Publié : 05/06/2026 10:07 pm
