One perimeter objects isues
vojta
(@vojta-3)
Hi, I am testing a single perimeter object printing. There are two problems which I can not solve by slicing setup. One is adding material to the outer corners, which makes cornes rather ugly, than good looking.
Second one is joining perimeters (it is not a spiral vase case), at the start of the perimeter is a huge gap - more in a picture.
I tried many printing setup, without success. Any sugestion? Thanks
Respondido : 27/01/2023 9:21 am
RE: One perimeter objects isues
Save your slicer setup as a project. Then zip the project file. And attach the zipfile. And we can look at your settings and make suggestions
Regards Joan
Respondido : 27/01/2023 11:13 am
vojta
(@vojta-3)
1,6mmTest
Respondido : 27/01/2023 11:30 am
vojta
(@vojta-3)
Thank you!
R&D
 R&D
(@rd)
@vojta-3
This is not a slicer setup as a project. This is just a .stl file.
The request was for a Slicer project, a .3mf project file exported fro slicer, setup as you were trying to slice it, so we could see what you were doing wrong, and explain how to fix it.
Respondido : 27/01/2023 11:41 am
vojta
(@vojta-3)
I am sorry, confused with my own files. This is the right file 3rmf.
Respondido : 27/01/2023 2:52 pm
vojta
(@vojta-3)
And project after slicing the object if it is needed.
Respondido : 27/01/2023 2:57 pm
vojta
(@vojta-3)
Thank you!
Robin
(@robin)
Only the 3mf project file saved in Slicer and zipped is needed. If you save it before or after slicing does not change anything....
Respondido : 27/01/2023 3:33 pm
OP might have meant the gcode file with "after slicing". No , please no gcode file
Respondido : 27/01/2023 3:47 pm
