Object manipulation World & Object coordinates
Rajah
(@rajah)
Hi all,
How can I set a cylinder of diam. 10 mm and 20 mm height on the top of a cube of 10 x 10 x 10 mm?
Napsal : 21/07/2024 5:40 pm
Ringarn67
(@ringarn67)
RE: Object manipulation World & Object coordinates
@rajah
1. Right-click on plate
2. "Add shape" -> "Box"
3. Resize box to 10 x10 x10 and put it at for example x100 y100
4. Right-click "Shape-box" in object window
5. Select "Add part" -> "Cylinder"
8. Resize cylinder to 10 x20 and put it at same place as box
9. Z-position for Box should be 5 (Z-centre of box), and for Cylinder 10.
10. Change Z-position for Cylinder to "20", that means the centre of the cylinder should be at 20mm height = 10 above plate
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Napsal : 21/07/2024 8:30 pm
Rajah
(@rajah)
Thanks Ringarn67,
So far so good but now with "cube" of 10  10 x 2 mm and cylinder of 10 x 20.
Can't get World coor. lifted to Z=11 !
Napsal : 22/07/2024 7:07 am
Ringarn67
(@ringarn67)
CylinderCenter (10) plus CubeHeight (2) is 12
Cylinder should be at 12 Z-position
Napsal : 22/07/2024 7:40 am
Rajah
(@rajah)
Correct: CubeHeight is 12. But can't get it up further than 10 mm
Napsal : 22/07/2024 9:04 am
Ringarn67
(@ringarn67)
is this helpful?
Napsal : 22/07/2024 9:09 am
Rajah
(@rajah)
Ehh... no. I have also encountered the problem of sinking. This question was meant to get a clear and simple understanding of how it works.
My actual goal is to get text (Shapestring from FreeCAD) ON a background of a 1st layer. 1st layer white and the text red.
I managed to do that once, but I don't remember how and I didn't save the file.
Can you help with that? 😉
Napsal : 22/07/2024 9:25 am
Ringarn67
(@ringarn67)
I have no experience of FreeCAD so I can't help you with that part
However, color change at certain height in PS is the easiest way to deal with simple signs
1. Export complete stl from cad-program
2. In Preview window, push the "+"- sign to correct height in "heightbar"
3. Rightclick and select "Add color change"
4. Done
Napsal : 22/07/2024 10:06 am
1 lidem se líbí
Rajah
(@rajah)
I am aware of that.
Tack!
Napsal : 22/07/2024 12:43 pm
Ringarn67
(@ringarn67)
Varsågod! 🤔
Napsal : 22/07/2024 1:28 pm
