Object doesn't fit – but it should fit!
Audax
(@audax)
Why? The Object should fit!
Publié : 20/08/2025 9:48 am
_KaszpiR_
(@_kaszpir_)
what's on the left side that is hidden?
also it looks like overhangs are outside of the bed
Publié : 20/08/2025 3:09 pm
Audax
(@audax)
RE: Object doesn't fit – but it should fit!
There‘s nothing outside the bed. Look at the dimensions at the right side of the picture. They’re smaller then the actual bed size.
Publié : 20/08/2025 3:37 pm
could you please attach your project file, including the model, as a zip file, on the forum
Publié : 20/08/2025 4:02 pm
Audax
(@audax)
It's only the "Haube" part.
Archiv
Publié : 20/08/2025 5:07 pm
Have you tried auto arrange. If that can't fit the object it is too large after all. But with the 3mf we can see what's going on.
Publié : 20/08/2025 9:24 pm
Mike B
(@mike-b-3)
Check the build plate size specified in the printer section.  The MK4 build volume is 250 x 210 x 220 - perhaps PS is still using that build volume instead of the Core One volume?
Publié : 20/08/2025 10:08 pm
try setting the number of skirt loops to '0'
the skirt loops are placed outside the model making it bigger than expected.
Publié : 20/08/2025 11:34 pm
1 personnes ont aimé
Audax
(@audax)
Posted by: @foxrun3d
Of course.
Publié : 21/08/2025 7:13 am
_KaszpiR_
(@_kaszpir_)
Set no skirt, no brim, so it is the only object to be printed.
Object size 220, bed size 220 - that may be a problem, set bed size to 221 and try again ( I believe core one should have those extra millimeters out there...). I once had an issue on the Mini and had to change that to force fit the print.
If that does not work you will have to shave off some model with using negative volume on the side to make it fit, or rotate object vertically.
Publié : 21/08/2025 8:12 am
Skit/brim are set to 0, so OP is okay.When positioned to lie flat and rotated 90 degrees, the object size is 238.46 x 220, so should fit (Core One sheet is 250 x 220). But it doesn't like the 220 size in y direction. If you scale it to 219.6 y-size, it sliced okay. Feels like a bug. I would report it on GitHub. Given the size of the object I would probably just try to print it with 219.6, and it will probably fit just fine with the other parts.
Publié : 21/08/2025 11:07 am
Audax
(@audax)
I reported a bug on GitHub. Thanks to all.
Publié : 21/08/2025 1:55 pm
That's not the Prusa slicer project file 3mf is it ?  When I load it it just gets the geometry on whatever printer I have selected at the time.  In this case a Max with a 420x420 bed so it fits easily :).
The reason we ask for a prusa slicer project file is that also includes all the profiles, so your print settings and printer etc.  Anyone opening a saved PS project basically gets every setting and modifier/placement etc you are using.  If I wanted to debug this then I would have to install a core one printer too.
As the others say I suspect this is a bug, in that the logic should be if object bounds are 'less than or equal to bed size' then its ok.   What it appears to be using is 'Less than bed size'.  Increasing bed size to 220.01 is enough to slice, at least on a printer profile I cobbled together for testing purposes.  Without installing a core one profile and modifying that though the result is more of a supposition of concept.
Publié : 21/08/2025 7:26 pm
