Object->Add setting->Custom Gcode
rait
 rait
(@rait)
Is there a way to add custom G-Code to an object in PrusaSlicer? Right now I'm dialing in my retraction settings and would love to dot the build plate with test pieces and use different retraction parameters for each one. The way I've ended up doing it is exporting the G-code, then opeing it in a text editor to find corresponding locations and add my Gcode. That's not terribly convenient.
Opublikowany : 23/04/2020 6:03 am
Dhaya
(@dhaya)
RE: Object->Add setting->Custom Gcode
Hi, you can right-click on the "+" sign next to the layer bar to add a custom G-code, you can get more information here: https://help.prusa3d.com/en/article/insert-pause-or-custom-g-code-at-layer_120490/.
Opublikowany : 23/04/2020 7:41 am
Dhaya
(@dhaya)
Oh my bad, I didn't see you wanted to do that regardless of layer height, but instead in relation to an object. For now I don't think this is possible. You could check out https://github.com/prusa3d/PrusaSlicer/issues for related issues or add your own so the development team can hear about it.
Opublikowany : 23/04/2020 7:49 am
Sounds like you are doing exactly what Bobstro did.  Have a read of Bobs reply to another user in this thread https://forum.prusa3d.com/forum/prusaslicer/use-height-range-modifier-for-specific-parameters/
Opublikowany : 23/04/2020 10:02 am
