not printing outer "square" with multiple extruder
KTH
 KTH
(@kth)
i am calibrating string issue so i set up multiple extruder on my model.
But only extruder #1 is printing correctly.
other extruder # is not printing the outer "square" before zigzag inside.
Opublikowany : 05/06/2021 3:35 pm
KTH
 KTH
(@kth)
RE: not printing outer "square" with multiple extruder
https://drive.google.com/file/d/1xaI4KqWHvNnJedtICxrvu46tqZT4Jnmm/view?usp=sharing
gcode for it
Opublikowany : 05/06/2021 4:30 pm
Generally we don’t download random stuff from external sites. Also gcode is not very useful in debugging issues. What’s really needed is your project file.
You can follow this guide on how to do that https://forum.prusa3d.com/wp-content/uploads/2021/05/Creating-and-Posting-a-project-file.pdf
With the project anyone can duplicate your slice results and easily check all the settings you are using. The person you want to take a look though is Bobstro as he has lots of experience using a virtual multi extruder setting to test settings.
Opublikowany : 05/06/2021 4:46 pm
Ringarn67
(@ringarn67)
@kth
I was not granted access. Put up the 3mf-file here instead
https://forum.prusa3d.com/wp-content/uploads/2021/05/How-to-save-and-upload-a-project-1.pdf
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Opublikowany : 05/06/2021 4:47 pm
Swiss_Cheese
(@swiss_cheese)
@kth
As neophyl and ringarn67 have mentioned post your zipped up .3mf file and we'll try to help.
Good Luck
Swiss_Cheese
The Filament Whisperer
Opublikowany : 06/06/2021 6:22 am
KTH
 KTH
(@kth)
retractiontest
Here is the 3mf file.
I notice that the hot end is making the movement of the "square" but no filament is coming out.
then it goes zigzag inside with filament coming out.
Opublikowany : 06/06/2021 2:20 pm
