Not printing full size
I'm doing a big print on my Ender 3 that's 215mm x 215mm. I run it through Prusaslicer no problem, it's previewed as being 215mm x 215mm. But when I put it on the SD card and try to print it out, it draws the dimensions at 154mm x 215mm. I've checked the printer settings inside Prusaslicer and it's reading my bed at the correct size (220 x 220) . I slice the excat same file through Simplfy and it prints correctly.
Opublikowany : 07/07/2023 5:03 pm
