Not able to set overhang threshold
[Solved] Not able to set overhang threshold
miodo2010
(@miodo2010)
Hi all,
unfortunately I'm not able to set the overhang threshold in print settings: although being in Expert-mode, the field is greyed out, it is not possible to change the value.
Ticking Auto generated supports on or off does not change anything.
Any ideas what I might do wrong?
Best regards
Michael
Best Answer by JoanTabb:
have you ticked "Generate Support Material?"
Posted : 13/05/2023 11:59 am
RE: Not able to set overhang threshold
Posted : 14/05/2023 3:48 pm
miodo2010
(@miodo2010)
Thanks a lot, JoanTabb, that did the trick! 🙂
Posted : 20/05/2023 3:27 pm
