Normal infill mode to vase mode is there a way
Tinkerwest
(@tinkerwest)
I’m trying to convert a design from S3D to Prusa Slicer and running into a problem. The design started printing in normal infill and then switches to vase mode. I tried to use the modifiers but I do not see an option to switch to vase mode. I can switch to 1 perimeter and zero infill but that will leave a seam.  If I try to start in vase mode and then switch the modifiers will not let me change. Not sure if I’m missing something, any help would be appreciated.
Best Answer by Tinkerwest:
@tim-2
FYI - I found a workaround, I increase the bottom layers. Not a perfect as you get completely solid. But 26 layers did the trick for me. My figure is 150 mm high and has plug at the bottom that is about 5 mm high and needs to be stronger. So not a major penalty having a solid base versus 20%.
Veröffentlicht : 09/05/2021 4:20 am
RE: Normal infill mode to vase mode is there a way
Pretty sure vase mode is 100%, or not available in Prusa's Slicer. The option is to use the modifier to go from X perimeters with infill to 1 perimeter with 0 infill - and as you have discerned, there will be a seam. You might try randomizing the seam to make it less visible. A well calibrated printer does a fair job in that case. Not vase quality, but it can get close. Or bury the seam at the rear.
ps: or keep it in Simplify and use that gcode.
Diese r Beitrag wurde geändert Vor 5 years von --
Veröffentlicht : 09/05/2021 5:45 am
Tinkerwest
(@tinkerwest)
@tim-2
Veröffentlicht : 10/05/2021 1:23 am
@tinkerwest
There is always casting resin to weight the base. But if a solid print works, it is quick and easy. Cheers!
Veröffentlicht : 10/05/2021 3:48 am
Mitglied
@tim-2
You you could add some clay.
Veröffentlicht : 10/05/2021 6:53 pm
@cwbullet
When replying to a thread - PLEASE - reply to the correct party. I hate getting emails when I've unsubscribed to a thread.
Veröffentlicht : 10/05/2021 9:52 pm
Mitglied
@tinkerwest
You could add clay to the base to add weight.
Veröffentlicht : 11/05/2021 2:08 am
