No supports
SailWood
(@sailwood)
No supports
Hello,
I don't understand why Prusa slicer doesn't produce support on the middle of the horizontal part .
Can you help me ?
Thank you,
Attachment removed
Best Answer by Area51:
If the middle part is a bridge (blue) this option has to be turned off to generate support:
You need to in Expert or Advanced mode to see this option.
This topic was modified 6 years temu by SailWood
Opublikowany : 04/09/2020 9:39 am
Area51
(@area51)
RE: No supports
Opublikowany : 04/09/2020 10:15 am
RE: No supports
What @area51 said. If PS thinks it can handle bridging it won’t produce supports.
Opublikowany : 04/09/2020 12:58 pm
SailWood
(@sailwood)
RE: No supports
@area51 Yes ! It works, thank you.
@fuchsr : PS thinks but it's not working well... thank you for explanation.
Thank you,
Opublikowany : 04/09/2020 1:01 pm
RE: No supports
@eric-7
Yeah, it depends. I’ve seen it produce gorgeous bridging but also shall we say suboptimal.
Opublikowany : 04/09/2020 1:03 pm
SailWood
(@sailwood)
RE: No supports
I use ASA to print this piece. Supports are needed for this part but they are very easyly removable with ASA.
Opublikowany : 04/09/2020 3:17 pm
