No ramping lift between support structures
objectId
(@objectid)
Mitglied
PrusaSlicer 2.7.2
Ramping lift max 1.5mm at 8*, steep ramp before obstacles...
I am observing the lift happen only when the toolhead moves from the model to a series of organic supports. When it travels between the supports, no lift, and no lift when completing supports and traveling back to the model..
Is there a setting I am missing somewhere?
Veröffentlicht : 22/03/2024 1:39 pm
HaroldCortez
(@haroldcortez)
Mitglied
RE: No ramping lift between support structures
Ensure that the 'Retract On Layer Change' setting is enabled.There was an issue reported where the 'Use Ramping Lift' should force this setting to be on for proper functionality.
tunnel rush
Veröffentlicht : 25/03/2024 9:42 am
objectId
(@objectid)
Mitglied
Confirmed 'Retract on Layer Change' is enabled as well, I had heard this too... much appreciated for the input tho! Anything else? It's strange, it definitely hops from the model to the first tree, then stays level travelling like 40-50mm maybe to the next tree, does a whole bunch close together, which seems fine, but then it doesn't hop when travelling from the last tree back to the model on the other end of the bed.
Veröffentlicht : 25/03/2024 1:08 pm
