No ability to define 1 or 2 bottom layers
Volodymyr Onyshchuk
(@volodymyr-onyshchuk)
Miembro
Hi!
Faced with a funny bug, I cannot define 1 or 2 bottom layers in the PrusaSlicer (2.7.0).
With 0 bottom layers in settings - 0 in slicer.
With 1 layer in settings - 3 in slicer.
With 2 layers - 3 in slicer
With 3 layers - 3 in slicer.
With 4 and more -  works as expected.
Respondido : 05/12/2023 9:30 am
RE: No ability to define 1 or 2 bottom layers
I can't reproduce this. Are you sure you don't have minimum shell thickness for Bottom set to a value that is at 3x layer height, which would explain what you're seeing?
Respondido : 05/12/2023 12:11 pm
Volodymyr Onyshchuk
Miembro
OOOOH! you are right! thank you 🙂
But interesting that it still works for 0, minimum thickness ignored.
Esta publicación ha sido modificada el hace 3 years 3 veces por Volodymyr Onyshchuk
Respondido : 05/12/2023 12:27 pm
I'd almost lay money on the minimum shell thickness being the issue.  By default its 0.5mm isnt it, which would translate to 3 layers at 0.2 to bring it above 0.5.
Respondido : 05/12/2023 5:37 pm
Volodymyr Onyshchuk
Miembro
Yes, you are right. Didn't face previously with this setting, always adjusted only number of layers, so was stumbled that it didn't work.
Respondido : 06/12/2023 9:33 am
