New with Prusa Slicer odd speed
[Rozwiązany] New with Prusa Slicer odd speed
pL0ck
(@pl0ck)
Hi All
Fairly new with Prusa Slicer. Using 2.6 beta 2 on Win 11. I like some of the options compared to Cura so have setup some profiles and copied settings to try and match. I does print OK but I noticed it takes longer than Cura. Started digging into the settings a bit more. If I set the overall speed to 80 and then slice it seems to show things like infill at a much slower speed (around 20-30). I'm sure there is some setting I've missed but still working my way around the interface 🙂
Any help would be appreciated. Cheers Peter
Opublikowany : 23/05/2023 2:03 am
pL0ck
(@pl0ck)
RE: New with Prusa Slicer odd speed
I think I answered my own question.
Under Filament Cooling is an option to reduce speed if layer time is below a certain number of seconds, and also a min print speed. Obviously need to get used to where the various settings are. Thought those options would be under print rather than filament, so ended up being just a noob question.
Cheers
Opublikowany : 23/05/2023 2:15 am
