Multicolor print changes height about 10 mm when changing tool
Pertti
(@pertti)
Hello everybody and Josef especially
I just started using the latest 2.5.Prusaslicer with my custom Toolchanger. Thank You all for Your contribution to the printable world.
My first multicolor print failed due sudden height changes. That happens when changing the tool. I have found no way to control this. Cura works ok. I have Duet Wifi motherboard and RR3 firmware.
Thanks in advance for answers.
Pertti
Publié : 19/11/2022 9:32 pm
RE: Multicolor print changes height about 10 mm when changing tool
Hi and welcome. Unfortunately this is mainly a user to user forum.
Someone here may be able to help but to do so they would need much more information. Usually at a minimum a saved copy of one of your PRUSA slicer projects. File>save project as. That will save a 3mf file that contains all the settings you are slicing with as well as the model. To attach one here it will need zipping up or the forum won’t accept it.
To raise an official query then that needs to be done on the PRUSA slicer GitHub at https://github.com/prusa3d/PrusaSlicer/issues  that is where all the official reports get raised and tracked.
Publié : 19/11/2022 9:53 pm
