Multicolor Painting Slicing With Errors
mgantner
(@mgantner)
Painted a piece with several colors
 Painted object
and when slicing the object the colors are being messed up on some layers.
Sliced object
Sliced object
I've repainted it in new projects with same results in Prusaslicer 2.7 and 2.7.1
Slicer screenshots
Anyone else see this behavior?
Postato : 14/12/2023 10:51 pm
BaconFase
(@baconfase)
RE: Multicolor Painting Slicing With Errors
It's usually a model issue that you'd have to fix in CAD.
Sometimes it's because you miss a tiny triangle or two when painting and for some reason that missed triangle's different color explodes over the whole layer.
I have also seen this type of issue 'randomly' popup between versions of PS but I'm not programmer enough to know why. I particularly remember this issue happening to me between PS 2.4.0 vs 2.4.2-rc2, but nothing came of it. If you slice the file I uploaded in 2.7.1 it still happens, so they never got around to fixing whatever causes that. So if the first two things don't work out, you could try slicing in older versions of PS.
XL-5T, MK3S MMU3 || Printing with multiple nozzle-sizes: Official Guide, Unofficial || PrusaSlicer Fork || Other advanced slicer tactics || TPU
Postato : 15/12/2023 12:02 am
mgantner
(@mgantner)
Thanks for the reply, it was very helpful. Couldn't fix the model, but not painting a couple surfaces solved the problem. Not exactly how I wanted it to look, but close enough.
Postato : 15/12/2023 2:53 pm
