Multi-Quality Prints ?
Parrot
(@parrot)
In PrusaSlicer 2.6.0, is it possible to do different quality settings on the same print? For example, if I want most of an object to be printed at 0.20mm Quality, but for the last few layers I want to switch to 0.05mm Ultradetail. Is this possible?
Napsal : 30/08/2023 11:14 pm
Antonio
(@antonio)
Member Moderator
RE: Multi-Quality Prints ?
yes, on the top toolbar there is the "variable layer" function that allow you to do exactly that
I'm not an expert. Ma parlo anche italiano 😉
Napsal : 31/08/2023 10:32 am
The variable layer function is one option but hard to work with if you need precision. Another option is to use a height range modifier and adjust the layer height that way.
Napsal : 31/08/2023 12:03 pm
Robin
(@robin)
Also you really want to stay away from 0,05mm layer height with a standard 0.4 nozzle...
Napsal : 31/08/2023 7:15 pm
