Multi object 3mf files no longer importing as a single model
jens
 jens
(@jens-6)
I used to be able to drag a multi object 3mf file into PrusaSlicer and it would pop up a message box asking if the objects were all part of the same print (or something to that extent). When I now drag a 3mf file into the slicer, it recognizes the different bodies but no longer pops up the window asking me how to handle the bodies.
The printer is set up as a 4 tool unit.
What did I bugger up and how can I fix it?
Postato : 15/08/2023 7:36 pm
jens
 jens
(@jens-6)
RE: Multi object 3mf files no longer importing as a single model
Another interesting point - if I drag in 2 STL files at the same time, PrusaSlicer asks me how I want to treat the individual parts, just iike it should.
Postato : 16/08/2023 5:11 pm
jens
 jens
(@jens-6)
I have finally found the issue ..... and it's a weird one alright.
If I create two bodies in Fusion360, save them as a single 3mf file, drag that file into PrusaSlicer then PrusaSlicer asks how to treat the two objects.
If I create one body in Fusion360, split it into two, save the resulting two bodies into a single 3mf file and then drag that file into PrusaSlicer, PrusaSlicer then recognizes the two bodies but no longer asks how to deal with the two bodies.
I do not know if this is a Fusion360 issue or a PrusaSlicer issue.
Postato : 17/08/2023 3:53 pm
