Moving from Cura tu Prusa Slicers things I can't find
alc112
(@alc112)
Helo! Cura is  getting slower and slower inmy PC so I thought I would give Prussa slicer a try but I can't figure out some features I really need to replace it.
I can't find a way to  group and ungroup objects the same way I do it in cura. Here is some context. Maybe this can help
I mostly make keychains with multiple colors with one extruder. My work flow is as follows:
I desing the keychain in fusion 360. I get a lot of bodies becuase each one has differnt colors (for example 30 bodies and 6 different colors for one keychain). I name every body with the corresponding color.
I import them all in cura, hit merge (which places every object the same way I see them in fusion 360 and with its corresponding  height)
I multyply the merged keychain
I ungroup all and manually group all the files in the different colors.
I delete all created groups except for one and generate a gcode file. I repeat this for each color (they are only 3 layers height except for the last one that is 11)
Opublikowany : 28/04/2022 2:08 pm
