Mold cavities using the negative volume function
RedDawg
(@reddawg)
I don't think this is presently a "thing". If it is please enlighten me. If it isn't, I guess I'm off to Github.
I frequently print small items that I would like to make into negative molds which then can be filled with various pourable resins. I would love a technique/feature in PS whereby the item is rendered as a negative volume within an encompassing positive shape. I recognize I would probably have to manually add "spru channels" for pouring and some geometries would not be possible. For instance, a "thru" hole would require a floating positive cylinder within the negative volume. Fortunately,  my items do not have such negative spaces to begin with, or at least with round holes, I could possibly add them by drilling, post removal.
Is this worth pursuing as a slicer feature? Other suggestions to achieve this? I'm ignoring shrinkage or expansion of various materials at this stage of discussion.
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Publié : 12/08/2025 6:38 pm
RE: Mold cavities using the negative volume function
You can already use any model as a negative volume.  So what's stopping you already doing this ?
Publié : 12/08/2025 6:57 pm
RedDawg
(@reddawg)
A fair question. I guess some experimentation is in order.
Publié : 12/08/2025 7:10 pm
RedDawg
(@reddawg)
First attempt: Created a "new part" (block) of sufficient size to enclose the item. When added as a negative volume, the item was roughly 200% in size. As a check, I added as a positive volume. It was normal (100%) sized. Stumped.
Publié : 13/08/2025 12:12 pm
cant help you there without a saved prusa slicer project file to see the issue you are having.
Publié : 13/08/2025 8:21 pm
