Modifiers based on Layer Height?
[Rozwiązany] Modifiers based on Layer Height?
Durahl
(@durahl)
Greetings!
Is it possible to apply Modifiers based on Layer Height, like how one can add an M601 Pause command, instead of using a Modifier Geometry?
A model I'm currently working on would benefit by having a range of layer use one instead of two perimeters and while it certainly is possible to do this with Modifier Geometries the precision as to where such a Mod would start or end is rather lacking.
Thanks in Advance 🙃
Opublikowany : 14/11/2020 3:08 pm
RE: Modifiers based on Layer Height?
https://forum.prusa3d.com/forum/prusaslicer/infill-adjustment-by-layer-height-is-it-possible/
Have a read of that thread for how to add height range modifiers.  Any of the options you can add with normal modifiers can be added with a height range one too.
You may also want to read the published knowledge base article for Prusa Slicer located here https://help.prusa3d.com/en/category/prusaslicer_204   modifiers including height based ones are covered.
Opublikowany : 14/11/2020 4:02 pm
1 ludzie polubili
Durahl
(@durahl)
Mhh... Ya... Feeling slightly embarrassed to not have seen the Height Range Modifier in the same RMB Context Menu I found the other Modifier in.
Regular sleep schedules could have prevented such an oversight, I guess 😐
Thanks for the help 🤣
Opublikowany : 15/11/2020 12:17 am
