Modifier creates unwanted divisions in top- and bottom layers
Remvs
(@remvs)
I have used Modifiers to locally increase the infill% near screw holes. But I am left with top- and bottom layers becoming non-continuous.
(see attached images). I am a bit scared it will impair overall strength. Is there any way to prevent this? I can imagine placing the  modifier cube a few mm from the bottom and top layers might do the trick, but that seems a hassle.
Thanks!
PrusaSlicer 2.1.0+win64
Opublikowany : 20/09/2019 11:04 am
richard.l
(@richard-l)
Member Moderator
RE: Modifier creates unwanted divisions in top- and bottom layers
I wouldn't increase the infill with a modifier for a screw hole.
What I would do is drop a Cylinder modifier on the screw hole and then increase the perimeters from what looks like 2 to 4 or 5.
Opublikowany : 20/09/2019 1:19 pm
Remvs
(@remvs)
@richard-l
Thanks!
That indeed was/is my first improvement for strength, however, when you have low infill% you still run the risk that these strengtheneth walls of your screw hole are hardly connected to the infill.
Opublikowany : 20/09/2019 2:04 pm
You have to adjust the modifier so that it doesnt intersect the top or bottom layers to get it to work without it casing that problem.  Which is a right pain admittedly.
Opublikowany : 20/09/2019 4:50 pm
1 ludzie polubili
Not to take away from anything being discussed, but earlier versions of Slic3rPE operated as expected:
Opublikowany : 20/09/2019 8:01 pm
Well, sort of...
Opublikowany : 20/09/2019 8:08 pm
I just ran into this myself: a pain.  Things work, then they don't.
Opublikowany : 21/09/2019 1:01 am
